csp86
Apr 02, 2020Follower
RAX80 keeps dropping
I have had my router lose internet connection to both wired and wireless devices pretty much daily. I have to reboot the router to make it work again. I have seen similar posts but no real solutions....
dj2819
May 21, 2020Apprentice
Spent a month trying to figure this out with the RAX120, no luck and support has no idea. Would recommend either waiting for some magic firmware update or do what I did and return it for some other brand (all of Netgear's latest offerings have some issue similar to this). I switched to the Linksys Velop MX5 and it worked perfectly out of the box.
LouisMorel
May 24, 2020Aspirant
Same problem here. Have Firmwareversie V1.0.2.76_1.0.35.
What you all did, I did also. Nothing helps. Its a shame that Netgear do nothing about it.
I have the problems with an older version, the Netgear Nighthawk. Same problem.
I bought the RAX80 to solf this problem, but the problem is still there.
I think I switch to Asus. A colleague has good experiance with that.
Bye bye Netgear.
- FlipandoSep 06, 2020AspirantSame problem here! They just conned me I to signing a gear head contract saying they could help. Then I find out after 2 hours on the phone and a day later the problem was still there. I have spent the last 3 months trying to figure it out and I finally got fed up with it and called o pay to find out today that I am 1 month past my warrantee. Glad o spent the money on the support to fix my janky $400 router!
