RickFranks
Jan 09, 2023Follower
RAX80 LAN Ports Voltage Specs
I have an RAX80 Router and would like to connect a PoE security camera to one of the LAN ports that I would be able to access with software on a PC over my home network. I can't find any specs on the...
- Jan 09, 2023
Since the ports are not powered, you will need to use a compatible POE injector (many are in the $15-20 range), They can work well if you need to use just one camera or other PoE device, but if you need to run multiple cameras, then consider getting a PoE switch, many decent 5-8 port units can be had for around $50.
Razor512
Jan 09, 2023Prodigy
