branchbiker
Aug 01, 2020Apprentice
RAX80 latest firmware V1.0.3.98_1.0.46 breaks router TIME
Today I upgraded the RAX80 to V1.0.3.98_1.0.46 This seems to have broke the system time on the router. It's is in an continous loop of about 1 min based on the time it gets after a reboot. Th...
sreeni_pa
Aug 02, 2020Guide
Hello,
I have updated Firmware on 08/31, since then my WiFi connection is being dropped intermitentatly.
When should we expect a fix for the issue?
Thx,
Sreeni
branchbiker
Aug 02, 2020Apprentice
Noticed the wifi dropping too. Had to reflash to .88. what a annoying mess.
- sreeni_paAug 02, 2020Guide
How did you do that?
Thx,
SK
- branchbikerAug 02, 2020Apprenticehttp://www.downloads.netgear.com/files/GDC/RAX80/RAX80-V1.0.3.88_1.0.41.zip
This is the previous version.- sreeni_paAug 02, 2020Guide
Thank you..
Planning to give couple days to Engineering to comeup with a hotfix before rolling back.
Cheers,
SK
