branchbiker
Aug 02, 2020Apprentice
RAX80 latest firmware V1.0.3.98_1.0.46 breaks router TIME
Today I upgraded the RAX80 to V1.0.3.98_1.0.46 This seems to have broke the system time on the router. It's is in an continous loop of about 1 min based on the time it gets after a reboot. Th...
Jaydawgx7
Aug 05, 2020Tutor
branchbiker Thanks for the heads up. I started the return process on Amazon just so I don't run past my return period. I'm going to research other brands too I guess, but want to stick with Wifi 6 since I already replaced the cards in a couple devices... Factory reset is an absolute PITA. I have over 60 devices connected and when I got my replacement router, it wreaked havoc on all my smart devices. Also ended up causing duplicate entries for most of my devices on my Home Assistant server . Factory resetting is a days worth of work to fix for people that actually use any advanced features like setting up static leases and port forwarding; this is NOT a solution, Netgear.
Christian_R Are there any updates on these issues? I'm not really a fan of having a $400 paperweight, especially when I work from home 100% now and this is affecting my job.
daweidu
Aug 05, 2020Star
block kid pc today. wow everything is broken. I reboot the router and still can not access the web interface. excellent software so they can keep their job.
