branchbiker
Aug 01, 2020Apprentice
RAX80 latest firmware V1.0.3.98_1.0.46 breaks router TIME
Today I upgraded the RAX80 to V1.0.3.98_1.0.46 This seems to have broke the system time on the router. It's is in an continous loop of about 1 min based on the time it gets after a reboot. Th...
Nmouneimne
Aug 06, 2020Apprentice
Had similar problems with Time and Cicle would not set up at all for me. Once I downgraded to .88, it all went back to normal.
branchbiker
My sons Xbox wasn't working so spent Saturday morning troubleshooting. I was pretty sure it was firmware related since it was fine before the upgrade but took me a couple hours to realize is the the time that was not updating. I kept trying all the circle settings and discovered it was bedtime that was causing the problem and then but two and two together. I have a Google nest wifi dual router kit coming tomorrow. I'll see how that works out and then hasta la Vista nighthawk (I've pretty much had it with this router which surprisingly still ranks very high on the reviews).
- branchbikerAug 09, 2020Apprentice
I sold the RAX80 on eBay and replaced with a 2 router Nest WiFi Kit. I just couldn't deal with the firmware headaches.
- Jaydawgx7Aug 12, 2020Tutor
branchbiker Luckily I'm still in my return window on Amazon, but I went a similar path. Just ordered the Nest Wifi with two Points. Even after downgrading the firmware to the 88 version, I'm still having issues. My modem/router are on a battery backup. Last night the power flickered causing all my smart devices (which are connected to the 2.4 network) to restart at the same time. Router couldn't handle it apparently and just stopped broadcasting the 2.4 network. Not the first time this has happened, just the first time I saw the cause. Disappointed to leave wifi6 behind, but I'm over this hunk of garbage. I wish the rest of you good luck.
- Christian_RAug 12, 2020NETGEAR Employee Retired
Hi Nighthawk AX Community,
For those experiencing issues with NTP Timezone, please send me a message with your email address and serial number.
Christian
- sreeni_paAug 20, 2020GuideDear all, Are there any updates on this firmware fix? Thx
