dehinson64
Oct 27, 2019Guide
RAX80 Logs
Hello, I have intermittent problems with my RAX80. Sometimes the internet drops, cannot log into router hard-wired, internet speed drops to 10mbps. So, the only things I can do is re-booted the rout...
dehinson64
Oct 27, 2019Guide
Also, why does FAST.com show that I have over 220mpbs internet speed and when I use SpeedTest while dialed into the router, I tells me only 25mbps. Netgear, I am about to go ask for a refund and gt a different router from another company!
microchip8
Oct 27, 2019Master
You are beta testing. All RAX models have firmware issues and do not support a few important WiFi 6 options and it's not sure they'll be added at all, if possible. I do not recommend getting any AX routers from any vendor at this point in time, unless you want to beta test and throw money out the window
