WenLu
Aug 18, 2020Tutor
RAX80 made in Vietnam has no fan inside?
I bought a RAX80 router which is made in Vietnam, and there is no fan inside, It manfactured in 2020 June. Just want to make sure that do Netgear remove the fan from New RAX80? Thanks.
- Aug 27, 2020
WenLu:
I asked the same question last month, was also told it has a fan, and was told to return it as defective if no fan. The device was purchased in July and was made in Vietnam.
I returned it, got a replacement, and exactly like the first unit, it too does not appear to have a fan.
From that I have now assumed that 1) either the fan is no longer placed right under the top grill, is really small and is out of sight within the unit, and NEVER runs, or, 2) there has been a design change and there is no fan.
I have had no hardware-related issues with the device, so I'm sticking with it.
Cheers.
Christian_R
Aug 25, 2020NETGEAR Employee Retired
Hello WenLu,
The RAX80 has a fan built into the device.
Christian
- WenLuAug 26, 2020Tutor
I bought my RAX80 in Taiwan,
I checked with Netgear agent, Netbridge Technology Inc.
They told me, RAX80 have no fan inside form 2020,
And my RAX80 have no fan inside for sure.
- jcaxAug 27, 2020Star
WenLu:
Cheers.
- WenLuSep 03, 2020TutorHi, Jacx,Thanks a lot for your reply,When I got my RAX80 last month, I tried to tune the fan always on from the hidden setting page.(RAX120 have this function)However,1.There is no fan setting for RAX80 in this page.(Maybe it’s removed form new firmware since no fan design change)2.I also accepted my no fan RAX80.
