djjuice
Mar 21, 2019Aspirant
RAX80 missing 160Mhz Channels
so it appears at some point, maybe the latest firmware update that the 160Mhz channels have been removed? I tried a factory reset with no change. I could go down a firmware but rather not.
righ...
- Mar 22, 2019
I'm set to the US, and I did a factory reset, my only option from here is to try a lower firmware, I usually use channel 149,1453, or 157 due to congestion on the lower channels, but this is just not available anymore, just the 60Mhz or the DFS channels. I'd use the DFS channels but I have devices that don't see the router then.
Edit: the mode was set to 4800Mbps, this reduces the channels, adjust accordingly and channels returned
avtella
Mar 21, 2019Prodigy
I have no such issue on the latest firmware,so my guess is some sort of corruption or wrong country setting? Try a factory reset.
For HT160 channels above 128 wont be available due to lack of contiguous bandwidth, so that’s normal.
