djjuice
Mar 22, 2019Aspirant
RAX80 missing 160Mhz Channels
so it appears at some point, maybe the latest firmware update that the 160Mhz channels have been removed? I tried a factory reset with no change. I could go down a firmware but rather not.
righ...
- Mar 22, 2019
I'm set to the US, and I did a factory reset, my only option from here is to try a lower firmware, I usually use channel 149,1453, or 157 due to congestion on the lower channels, but this is just not available anymore, just the 60Mhz or the DFS channels. I'd use the DFS channels but I have devices that don't see the router then.
Edit: the mode was set to 4800Mbps, this reduces the channels, adjust accordingly and channels returned
djjuice
avtella
Mar 22, 2019Prodigy
Oh you want HT80, then yeah you need to set it to 2300 Mbps option to get the upper channels.
