HenriCu
Jul 31, 2020Follower
RAX80 NAT config doesn't work
Hi, I try the NAT (DMZ) config, but doesn't work from outsite the LAN. I test i with a ssh connect to a RHEL Server behind the Router .
The DMZ has the IP from this RHEL server. Some ideas?
1 Reply
- Christian_RNETGEAR Employee Retired
Hi HenriCu,
I would suggest getting in contact with our support to look into this further.
https://www.netgear.com/support/default.aspx
Christian
