onurich01
Aug 06, 2020Tutor
RAX80 Netgear NTP Not Syncing/Clock not Advancing
My RAX80 Clock was last sync'd 05AUG 11:07. It will not re-sync, and the clock has not advanced since. My log continues to fill with the same time log for each event. The seconds increment but the mi...
Nmouneimne
Aug 06, 2020Apprentice
I had an issue with my RAX80 not syncing the time on the latest firmware (1.0.3.98). I had to downgrade to 1.0.3.88.
- Pokemon888Aug 07, 2020Guide
I have just got this RAX 80..3 days ago. Circle unable to track time usage on devices. I have logged the call to support.
I have done the factory reset and wire uploaded new firmware ( V1.0.3.98_1.0.46 ) to the RAX80 router. Still the same. Clock not advancing and changing time zone to Melbourne failed to save after applied.
At this stage I am using V1.0.3.88_1.0.41 previous version. The clock is in sync and setting the new time zone- Melbourne also saved and Circle is working.Hope they correct the firmware.
- Pokemon888Aug 24, 2020Guide
New update :
Netgear Engineer is getting new firmware done.
