onurich01
Aug 06, 2020Tutor
RAX80 Netgear NTP Not Syncing/Clock not Advancing
My RAX80 Clock was last sync'd 05AUG 11:07. It will not re-sync, and the clock has not advanced since. My log continues to fill with the same time log for each event. The seconds increment but the mi...
SAM_the_GAM
Aug 25, 2020Luminary
onurich01 wrote:My RAX80 Clock was last sync'd 05AUG 11:07. It will not re-sync, and the clock has not advanced since. My log continues to fill with the same time log for each event. The seconds increment but the minute does not ever roll over.
I sent a private message to @Christian_R with my serial number & email address. I was sent the beta firmware which has solved the NTP Router Time Issue and ipV6 connectivity.
