steviev1
Sep 04, 2020Apprentice
RAX80 New Firmware Out Today
 1.0.1.128     New Features and Enhancements:   Supports the ISP profile menu, which includes ISPs from Europe and Asia  Supports Orange France IPTV  Supports Singapore Singtel IPTV  Supports the time...
avtella
Sep 04, 2020Prodigy
That's for RAX120.
Heres the one for the RAX80:
Security Fixes:
- Fixes security vulnerability issues.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
- Fixes the issue where the time zone can’t be set up manually.
 - Fixes issues with IPTV.
 - Fixes the issue where some devices can’t be renamed in the attached devices list.
 - Fixes the issue where port 1 and port 5 can’t be added to the VLAN bridge group.
 - Fixes minor bugs
Firmware Update Instructions:
Download Link: https://www.downloads.netgear.com/files/GDC/RAX80/RAX80-V1.0.3.102_1.0.48.zip
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAX80.aspx#docs.
- steviev1Sep 04, 2020Apprentice
You are correct.
Thank You
- jcaxSep 04, 2020Star
I took a chance and tried this upgrade to 102 on my RAX80. Successfully applied it after a bit of trouble.
Note that last week I had applied the "beta" 99 build from Netgear support that seemed to fix the NTP/log issue.
When I attempted to install this 102 build on top of the 99 it failed with not successful updating language table errors. Several times. Tried after a reboot with no success. I did a factory reset successfully. This then triggered the update to 102 as part of the initialization process. Update was successful.
As suggested in some other posts, rather than restore settings from a backup file, I have now gone through and re-entered my configuration changes to the "baseline" 102.
So far, all appears well with NTP/log error still fixed, and IPv6 seems to be working.
However, the display of attached devices still seems to have some issues like duplicate IPs, wrong type of connection, device not shown. This has been an annoyance in previous build(s), and seems to me to still have some troubles.
Cheers!
- daweiduSep 04, 2020Star
nice
 - hwyman11Sep 08, 2020Aspirant
Updated today and I am unble to connect to the 2.4ghz. wifi. I had to roll back to RAX80-V1.0.2.76_1.0.35 and I was able to connect to the 2.4ghz. wifi. Netgear, why can't you get this issue fixed?
