steviev1
Sep 04, 2020Apprentice
RAX80 New Firmware Out Today
 1.0.1.128     New Features and Enhancements:   Supports the ISP profile menu, which includes ISPs from Europe and Asia  Supports Orange France IPTV  Supports Singapore Singtel IPTV  Supports the time...
steviev1
You are correct.
Thank You
jcax
Sep 04, 2020Star
I took a chance and tried this upgrade to 102 on my RAX80. Successfully applied it after a bit of trouble.
Note that last week I had applied the "beta" 99 build from Netgear support that seemed to fix the NTP/log issue.
When I attempted to install this 102 build on top of the 99 it failed with not successful updating language table errors. Several times. Tried after a reboot with no success. I did a factory reset successfully. This then triggered the update to 102 as part of the initialization process. Update was successful.
As suggested in some other posts, rather than restore settings from a backup file, I have now gone through and re-entered my configuration changes to the "baseline" 102.
So far, all appears well with NTP/log error still fixed, and IPv6 seems to be working.
However, the display of attached devices still seems to have some issues like duplicate IPs, wrong type of connection, device not shown. This has been an annoyance in previous build(s), and seems to me to still have some troubles.
Cheers!
