steviev1
Sep 04, 2020Apprentice
RAX80 New Firmware Out Today
1.0.1.128 New Features and Enhancements: Supports the ISP profile menu, which includes ISPs from Europe and Asia Supports Orange France IPTV Supports Singapore Singtel IPTV Supports the time...
jcax
Sep 04, 2020Star
I took a chance and tried this upgrade to 102 on my RAX80. Successfully applied it after a bit of trouble.
Note that last week I had applied the "beta" 99 build from Netgear support that seemed to fix the NTP/log issue.
When I attempted to install this 102 build on top of the 99 it failed with not successful updating language table errors. Several times. Tried after a reboot with no success. I did a factory reset successfully. This then triggered the update to 102 as part of the initialization process. Update was successful.
As suggested in some other posts, rather than restore settings from a backup file, I have now gone through and re-entered my configuration changes to the "baseline" 102.
So far, all appears well with NTP/log error still fixed, and IPv6 seems to be working.
However, the display of attached devices still seems to have some issues like duplicate IPs, wrong type of connection, device not shown. This has been an annoyance in previous build(s), and seems to me to still have some troubles.
Cheers!
daweidu
Sep 04, 2020Star
nice
- daweiduSep 04, 2020Star
my god my god my god. it is gone.
- steviev1Sep 04, 2020ApprenticeWho knows....
The Netgear app said it was available and I already updated. I wish they would get this straightened out.- ToWn3rSep 04, 2020Initiate
Any idea if this helps w/ some of the issues related to having AX and Smart Connect enabled causing devices to disconnect and drop when connected via 2.4 GHz?
- steviev1Sep 05, 2020ApprenticeIt is back on the site now
- mikechwSep 05, 2020Initiate
I installed it today and it seems more stable than last 98 firmware..
Firmware 98 always stopping dishing out ip addresses after one day or 2..
My wifi devices will stop working after that, I had to reboot the router every one or two days.
I suspect I am getting DOS attack from the WAN port once in awhile and the router firmware hanged..
