steviev1
Sep 04, 2020Apprentice
RAX80 New Firmware Out Today
1.0.1.128 New Features and Enhancements: Supports the ISP profile menu, which includes ISPs from Europe and Asia Supports Orange France IPTV Supports Singapore Singtel IPTV Supports the time...
Remi2
Sep 07, 2020Aspirant
I have tried installing the new firmware today 3 times. It never worked. It looks like it is trying to download the firmware but nothing happens. I have to restart my router each time I try to be able to access the settings via the application.
michaelkenward
Sep 08, 2020Guru - Experienced User
How? It sounds like you may be using the browser graphical user interface and the built-in update process.
This is the best approach:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
This is best done with a wired connection to the router. Then things cant fail if the wifi dies as a part of the process.
- Remi2Sep 09, 2020AspirantI was having this problem using the iphone app. I went through the web interface and the update worked. thank you for your reply
