Ivan813
Dec 19, 2020Star
RAX80 New firmware showing on app but not on support site
Hi, Like the subject says when i log in to the nightwawk app it says to update the router firmware to version 1.0.3.106_1.0.50, but since i never upgrade firmware using the app i go to the support pa...
Dec 19, 2020Guru - Experienced User
It usually just means that the firmware was uploaded to the automatic update server first.
It actually tends to be the opposite way (pushed to the manual firmware option first) when they're "testing" it so fewer people get it.
