Ivan813
Dec 19, 2020Star
RAX80 New firmware showing on app but not on support site
Hi, Like the subject says when i log in to the nightwawk app it says to update the router firmware to version 1.0.3.106_1.0.50, but since i never upgrade firmware using the app i go to the support pa...
alokbhargava
Dec 21, 2020Tutor
Do you have the link to download 106 Firmware for RAX80?
Dec 21, 2020Guru - Experienced User
You can check using the built in automatic update. Or you can wait until it loads to manual server.
