jezdez
May 05, 2022Guide
RAX80 New Firmware V1.0.6.138_1.0.76 = No internet
I just wanted to give a heads up on my experience. I updated to firmware V1.0.6.138_1.0.76. The update happened with no issue and my status said it was connected to the Internet but there was no inte...
May 05, 2022Guru - Experienced User
After you updated, did you try a factory resets?
Its usually the first step we recommend after a firmware change if there's issues.
- jezdezMay 05, 2022Guide
Definitely not going to erase all my settings. So no I did not do that. Rolling back fixed the issue.
- plemansMay 05, 2022Guru - Experienced User
Next time make a backup and try the factory reset.
Fixes a lot of issues after firmware changes.
glad you got it working though.
You might mark it solved so others aren't still trying to fix it.
Solved by downgrading is not solved. Factory reset is a bit basic tbh...
