jezdez
May 04, 2022Guide
RAX80 New Firmware V1.0.6.138_1.0.76 = No internet
I just wanted to give a heads up on my experience. I updated to firmware V1.0.6.138_1.0.76. The update happened with no issue and my status said it was connected to the Internet but there was no inte...
May 04, 2022Guru - Experienced User
After you updated, did you try a factory resets?
Its usually the first step we recommend after a firmware change if there's issues.
jezdez
May 04, 2022Guide
Definitely not going to erase all my settings. So no I did not do that. Rolling back fixed the issue.
- plemansMay 05, 2022Guru - Experienced User
Next time make a backup and try the factory reset.
Fixes a lot of issues after firmware changes.
glad you got it working though.
You might mark it solved so others aren't still trying to fix it.
- jezdezMay 05, 2022Guide
Solved by downgrading is not solved. Factory reset is a bit basic tbh...
