jezdez
May 04, 2022Guide
RAX80 New Firmware V1.0.6.138_1.0.76 = No internet
I just wanted to give a heads up on my experience. I updated to firmware V1.0.6.138_1.0.76. The update happened with no issue and my status said it was connected to the Internet but there was no inte...
jezdez
May 04, 2022Guide
Definitely not going to erase all my settings. So no I did not do that. Rolling back fixed the issue.
May 05, 2022Guru - Experienced User
Next time make a backup and try the factory reset.
Fixes a lot of issues after firmware changes.
glad you got it working though.
You might mark it solved so others aren't still trying to fix it.
- jezdezMay 05, 2022Guide
Solved by downgrading is not solved. Factory reset is a bit basic tbh...
- plemansMay 06, 2022Guru - Experienced User
so not sure what you're expecting here. You don't want to factory reset after an update (which is recommended if there's issues) so you choose to downgrade.
- jezdezMay 06, 2022Guide
“I just wanted to give a heads up on my experience.“
