jezdez
May 04, 2022Guide
RAX80 New Firmware V1.0.6.138_1.0.76 = No internet
I just wanted to give a heads up on my experience. I updated to firmware V1.0.6.138_1.0.76. The update happened with no issue and my status said it was connected to the Internet but there was no inte...
cliff344
May 15, 2022Apprentice
I did not perform a factory reset. All the updates I have done previous with this router having owned it for several years did not require it, nor did it cause an issue. I have too many modified settings to go this route as it would take me some time to redo all the setting and modifications. The 132 firmware worked well so downgrading back wasn’t a problem for me.
May 16, 2022Guru - Experienced User
Try a factory reset next time. Sometimes a factory reset IS needed.
Also one should have a back up configuration saved to file for save keeping. Saves time if a reset is needed.
Good Luck.
- FURRYe38May 18, 2022Guru - Experienced User
Reset maybe needed for those that see this problem:
