EcoDieselDave
Sep 15, 2019Guide
Rax80 nighthawk can not connect to Carrier Infinity Thermostate
I switch to a Rax40 then to a rax80 a few days later. Ever since cannot connect to my Carrier Infinity Thermostat. I see another post with the same issue using or but No solutions The attached photo...
Christian_R
Sep 17, 2019NETGEAR Employee Retired
EcoDieselDave,
Please try disabling the AX and/or smart connect feature. Curious to know how this turns out!
Christian
- EcoDieselDaveSep 18, 2019GuideSmart connect cannot be used in smart homes as it confuses devices that must use only 2.4ghz
I'm unsure was the ax feature us but I had that off also. Still never worked.
Plugged in my 8-year-old ac1900 & no issues- Christian_RSep 18, 2019NETGEAR Employee Retired
Hi EcoDieselDave - I have sent you a message. Please check your inbox.
Christian
- EcoDieselDaveSep 19, 2019GuideChristian
I didn't get a reply & waited over a day it's 2019, & emails get replied to usually promptly especially from good tech companies.
I even wasted time trying to call in with NO help as No one could help, just transfer & transfer & hold.
So I plugged my old AC1900 TP-link back in which has Zero issues. Immediate connection to the tether app & Zero Smart Home issues both WiFI & Zwave. It's just so old it was time for an update to handle my gb internet Service
