JJ77
May 13, 2020Tutor
RAX80 nighthawk genie says will not work with bridged router
Century Link came in and hooked up a dual band modem WiFi CZ3000 and turned off WiFi on both bands. Now cannot connect nighthawk app to my router because it says it can't find the wifi. I need to bri...
- May 14, 2020
The minute you add wireless to a modem, you need something handling routing.
so you either have a modem or a combo device.
You potentially can put the CZ3000 in passthrough/modem only mode. I'd contact centurylink for the best way to set that up on their device.
May 14, 2020Guru - Experienced User
You can switch the router over to access point mode.
You loose out on some of the features of router mode but it keeps you out of a double nat.
- JJ77May 14, 2020Tutor
Would like to keep the features if I can. Is there such a thing as dual band modem without a router that would work with Century link DSL. Could find nothing on Google?
- plemansMay 14, 2020Guru - Experienced User
