Angelfire
Jul 13, 2022Aspirant
RAX80 Not getting IP --No Internet
Hello, Woke up this morning to no internet. We have XFinity service and generally it's been ok (couple of weeks ago it crapped out and after a number of reboots/reprovisions, it seemed to work fin...
- Jul 14, 2022
Many Thanks. I was able to get it to work last night. Not exactly sure what did it unfortunately. My modem had significant T3/T4 errors so I checked all my wiring...all good. Checked my signal strength, SNR etc...and that was all good. I disconnected the cable input to the modem as well as the Cat6 to the router and left them for about 5 mins . When I hooked them all back up, it worked. We had done all the reboots you describe before with no effect. I appreciate the response above and have copied it into my OneNote for future troubleshooting. I did learn about the Puma chipset so am now in the market for a better modem and I'll use this one as a backup should the need ever arise, I think. Cheers.
Jul 13, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I recommend changing the ISP modem model to something else. Theres a long standing issue with the 619x model modems.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Has a factory reset and setup from scratch been performed since last update?
- AngelfireJul 14, 2022Aspirant
- FURRYe38Jul 14, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
