rojicha07
Apr 01, 2022Aspirant
RAX80 not working with Android devices
Hey everyone, I hope you're doing great. So I had this RAX80 working perfectly. I had a modem/router combo from my ISP, but today they replaced it with a newer one. My service is 200/200mbps. ...
- Apr 02, 2022
If you have another router running on the network it causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
Apr 02, 2022Guru - Experienced User
- rojicha07Apr 04, 2022Aspirant
Thank you so much!! I tried the 2nd method and it worked perfectly! You're a life saver!! Thank you!!
