Htdevane
Mar 27, 2020Guide
RAX80 paired with U-verse Arris BGW210
I have basically done most of the things and I have successfully configured the IP Passthrough and now my Netgear Ax8 is my wireless router over the Arris gateway. When trying to get an open NAT type ...
- Mar 28, 2020You guys are the best! Removed IP Passthrough and enabled AP mode and boom the NAT type immediately went to open and all is well with the wireless connection. I just left the U-verse router Wireless disabled.
Thank you guys so much because I was literally about to go out and spend money on a mesh network but this AX8 is working good and it seems coverage also isn’t an issue with the router being in the corner of my living room and I’m still getting consistent speeds throughout my 2000sq ft house.
Mar 28, 2020Guru - Experienced User
Make sure the att device's passthrough/bridge mode is disabled. If you enabled it, it doesn't function properly but it doesn't mean that its fully routing. So make sure the ATT device is in in standard routing mode. :)
Htdevane
Mar 28, 2020Guide
- plemansMar 28, 2020Guru - Experienced User
glad to hear you got it working properly!
