conesbone
Mar 02, 2023Follower
RAX80 Port Forwarding Broken
Hi, I have an RAX80 router and am having troubles with port forwarding. I run an SFTP server on one of my computers (set to port 3108 with keypair auth) and also occasionally a game server. The i...
microchip8
Mar 02, 2023Master
I'm afraid, unless I can't think of anything else, you already tried all things except of a factory reset. The latter will most likely fix the issue. But it requires/strongly recommends you configure from scratch instead of using a backup config you may have, which can reintroduce the same problem.
