mmalevich's avatar
mmalevich
RAX80 problem connecting with work laptop
New to forums and no where else to go. I'm hoping someone can help me out with my router and connectivity with my work lapto.
Prior to setting up my new RAX80 my Dell Laptop had no problems finding and connecting to my old router.
When I purchased the RAX80 when pulling up available wireless connections, my Dell work computer does not identify that as an available option. This is the ONLY device this occurs with. It's not even listed as an option to select.
I've tried all the usual steps, unplugging, resetting, checking to see that it's not blocked somehow. Nothing seems to be working.
I'm pretty restricted on what settings I can toggle with from my work laptop so i'm hoping that it's something I can fix on my end. TIA for any advice or suggestions!
Matt
    • mmalevich's avatar
      mmalevich
      I just tried and it worked, thank you! I know nothing about that option, can you tell me what the downside is of doing that is?
      • plemans's avatar
        Many dells use an intel wireless card. And the dell website and windows update don't have the most recent driver for it.
        Find out specifically what wireless card is in the laptop. Then go to that device manufacturer's website and get the driver. I know intel had issues with this and you had to get the driver directly from them to get the functional driver.
  • I had the same issue with an Acer laptop, when I set up my router. Try looking at the Dell website for a newer driver for your laptops wireless network adapter, it helped in my case.
