Jimmy-60
Jul 22, 2020Follower
RAX80 question about blinking and red lights on router
My router has a blinking light on the top right hand side next to the WIFI light, why is this blinking? Also I have 2 blue lights and 2 red lights on the eathernet ports? # 1 & 3 are blue, 1 is the c...
Jul 22, 2020Guru - Experienced User
The manual has what all the led's are and what they mean.
It can be found here:
https://www.netgear.com/support/product/rax80
The top right is the wps light.
I think your "blue' for the ethernet lights is actually white, signify a gigabit connection. The "red" is actually amber and signifies a 10/100mbps connection.
