Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
Clovers
Jul 14, 2019Tutor
Thanks, just wanted to make sure Netgear was aware of the problem.
Panda9
Oct 07, 2019Guide
Rax80 keeps randomly disconnecting LAN and cycles a disconnect through devices which causes a moment without wifi for one device as others are ok. Once it reconnects, another device disconnects randomly. Latest update from 9-2019
- WarriOct 19, 2019Tutor
I'm having similar issues with Firmware V1.0.1.64_1.0.27 Any Advice?
It will randomly drop Network for probably 1-2sec but just enough for me to lose connection to game servers and discord.
- Panda9Oct 21, 2019GuideMine keeps doing it no matter what, i cant believe i spent 400$ on this router and I cant get any help or answer from Netgear. People are loosing hope out here.
- Christian_ROct 23, 2019NETGEAR Employee Retired
Hello Warri and Panda9,
I'd like for our support team to reach out to you and address the issue(s) you've experienced. When you get a chance, please send me a message with your contact info and case number (if applicable).
Thanks,Christian
- CloversNov 04, 2019Tutor
still a problem on Firmware Version V1.0.1.64_1.0.27
