Clovers
Jul 09, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
JamesJa
Nov 06, 2019Guide
Thanks, I did go ahead and roll back the firmware on the one unit that continually disconnects. Going to see if that solves the problem. Otherwise will open a support ticket. I just bought these three days ago
Jim
allarone
Nov 13, 2019Star
Will be interested to see if you have any luck. I have had mine for about 4 months and it has been complete garbage. I've tried so many potential solutions from the forum and nothing has worked. This started the day after I got my router. I keep hoping Netgear will come up with a firmware fix but they don't seem to be too interested. I may put my X6 back in for now and eventually by something from ASUS that I believe will be much better. Hate to waste $300+ on this junk but might be worth it to save any more aggravation.
- JamesJaNov 14, 2019Guide
After reading the forum, I downgraded my firmware to a previous version and the router went about a week but then it finally disconnected again. Support recommended reinstalling the most recent firmware and doing a hard reset. I did that two days ago and so far things are fine but it's too early to tell if that's a permanent fix. Strange thing is I bought two routers at the same time and the other one has worked flawlessly with no disconnection problems whatsoever. Going to give this one another week or two and if it continues to disconnect may possibly look into getting a refund or replacement. Should not have to deal with issues like this on a brand new expensive router.
Jim
- djphat2000Nov 18, 2019Guide
I've been having the same issue. Here is a list of things I have done to try and solve it to no avail:
1) This started on my X4S router. I thought maybe the internet port had gone bad. So I bought the RAX80.
2) I did not bring over my config. I started new, and just reused the same WiFi names as my old router, and IP addressing
3) Everything connected to it fine. I think I was on the .62 firmware at the time. However, my internet connection did drop once in 2 days.
4) It went fine for another couple of days, but then started to drop internet again. I rebooted, unpluged the internet CAT5. All worked for a few days. Then stopped working again.
5) I gave up and went to replace my "modem" from my ISP. Got that up and running, and again everything was fine for a few days.
6) Issue started again, keep dropping internet every day or so. WiFi appears "UP", but not getting any internet traffic in or out.
I wrote a post about my issue with the X4S. I didn't get any support reply back. So, I figured I'm the only one. I'm seeing that there are various issues with this and other routers from Netgear, and I guess I'm in the camp of "What GIVES?".
I have a lot of netgear products, and for the most part everything works. I'm very disapointed in the last 2 routers that I have had. Since getting them has not been an improvement on the next. Both had the same issue, even after changing out cable modems.
Is it the firmware? Does this get corrupted? The webpage is slower than my older router, and hangs up more often then the older router. I'm on the latest firmware, and I update when its available.
HELP
- JamesJaNov 18, 2019Guide
Sounds like a common problem. Following the community's suggestions, I reverted to an older firmware and my Internet would only disconnect about once a week rather than every day. Then support recommended I reinstall the most recent firmware which I did about three days ago and since then I've had no disconnects. Possibly downgrading and reinstalling the most recent firmware will help for you as well.
Jim
- Panda9Nov 19, 2019GuideIts been an ongoing issue for months but im not able to purchase another Router after spending soo much on this one. I was recommended to revert back an update but reset didn't do anything. How exactly did you guys re-install the recent update? Because when I check im fully up to date.
- Christian_RNov 20, 2019NETGEAR Employee Retired
Hi Panda9,
Please refer to KB article below on how to upload a firmware manually. When you get to step 1, you may choose which firmware you'd like to upload to your router.
https://kb.netgear.com/23960/How-do-I-manually-upgrade-firmware-to-my-NETGEAR-router
Christian
- djphat2000Nov 27, 2019Guide
I may try that.
However, I've since did a factory reset as everyone else has already done a million times. Of course, that did nothing, and actually made the issue come back more often. SO, I have an X4S and an older R6300. I was going to go back to the X4S however, that unit had the exact same issues the RAX80 has. Just drops internet. And usually what I would do is unplug the CAT6 cable from the modem going to the router and wait about 5 seconds and plug it back in. It would come back up and work for another day or so. This is the same issue as the RAX80 and the same solution works for a day or so.
There must be some kind of hardware/firmware issue here. The same code is causing the same issue on different hardware. I generally don't lose my WiFi, it happens but most of the time that isn't the issue. Just not getting past the router out to the internet.
Also, I think I mentioned that when I disconnect the CAT6 going to the modem. I drop all of the other network ports/devices for about 2 seconds. Those links go away, which has nothing to do with internet access. Like again they are tied together and it should not be. You should be able to use the "switch" independent of the Internet uplink port. Disconnecting the internet port shouldn't cause you to drop the LAN. Anyway. I've moved back to the R6300 for LAN/DHCP/Routing to the modem. Disabling the radio 2.4/5Ghz. I'm using the RAX80 for Access Point only and all the 2.4/5Ghz radio's it has. My main concern is watching AppleTV for my kid and not dropping that all day long.
WiFi again was mostly fine. So even if that starts to not work again. I can do a simple reboot to fix that.
From a network hardware perspective. This looks like bad firmware talking to the hardware and failing without recovering. There must be a software crash that happens. Don't know what triggers it though. However, when it crashes (OS-Firmware) the hardware just locks up and you drop your internet port or you lose your WiFi as others have stated happens. Turning features off sometimes seems to help some, but not always. Hardware wise, I'm sure this thing is MORE than capable of doing DHCP, Routing, and all the bandwidth etc. But, the software can't it seems.
- Panda9Nov 29, 2019GuideAnyone have any luck? My internet slowed down to an average of 400, instead of 900ish as i pay for a gig internet. And the disconnect continues.. Wish i could return this. I had high hopes but it gives mw a headache every day as a streamer..
- Panda9Dec 01, 2019GuideNo help from netgear or Amazon, looks like i now have to switch companies and spend another 400bucks for a router . This wont sit well with the community as an investor.
- allaroneDec 01, 2019Star
I feel your pain Panda9! After wasting hundreds of $ on Negear routers in the past several years the RAX80 put me over the edge. After only 4 months I shelved it and bought a TP-Link that has been flawless. Not one drop which is so refreshing after several every day with the RAX80. Good luck in your adventure. I for one am completely done with Netgear.
- charlesfisher87May 31, 2020Aspirant
I literally have had the EXACT same experience as you. Same devices and timeline etc. I've been really looking into this but haven't been able to resolve it. I really hope we both get some answers on this. Best of luck.
- SAM_the_GAMJun 02, 2020Luminary
There is a new firmware version 1.0.3.88 that resolves the LAN / WAN disconnections. Just have to do a factory reset after upgrading firmware.
- ubedawgJun 03, 2020Star
Thanks SAM_the_GAM What are you using to determine that there have been no drops? After a long time of getting booted out of online console games, I only figured it out by looking at the router logs. There were no other indications that a drop was occurring. I would be thrilled to be able to reconnect my xbox to ethernet instead of wifi, but I would like to be sure that this really was fixed before going through the hassle of a factory reset. The chances of remembering all of the settings are slim to none.
I just checked log files and sure enough, there are the dreaded entries that occur when the WAN disconnect occurs::
[Internet connected] IP address: xx.xx.xx.xxx, Wednesday, Jun 03,2020 11:33:35
[Time synchronized with NTP server] Wednesday, Jun 03,2020 11:33:34Huh. Another anomaly. I don't have any log entries prior to 5:30 today, just this repeated about a few hundred times. Weird.
Wednesday, Dec 31,1969 19:00:00
Wednesday, Dec 31,1969 19:00:00 - ChocobofarmJun 03, 2020GuideI get both anomalies in my logs too. The second one doesn't show up that often though. I didn't bother figuring out what it means or what causes it. But, from what I gather, it's mostly the first one that makes this router look like a bad joke for gaming.
- SAM_the_GAMJun 03, 2020Luminary
ubedawg wrote:Thanks SAM_the_GAM What are you using to determine that there have been no drops? After a long time of getting booted out of online console games, I only figured it out by looking at the router logs. There were no other indications that a drop was occurring. I would be thrilled to be able to reconnect my xbox to ethernet instead of wifi, but I would like to be sure that this really was fixed before going through the hassle of a factory reset. The chances of remembering all of the settings are slim to none.
I am checking the router statistics in the Advanced screen. I am checking the uptime. After about 48 hours WAN / LAN still disconnect and reconnect. However, the disconnections are happenning less often then with previous firmware giving the illusion that WAN / LAN disconnections is resolved.
- GabboCHJun 03, 2020ApprenticeI had both in my router logs too with all the firmware I've tried.
I hardwired my Xbox & tv's in both rooms to avoid the Wi-Fi problems only to see the same with LAN.
I have a tv with android & it shows a message every time "Ethernet cable disconnected " so it was pretty easy to see when out was occurring each time. - nchtrsJun 07, 2020Tutor
Wanted to use a wifi 6 router, since most of my devices are compatible.
First I bought the new AX6, had connectivity issues both wifi and LAN.
Fought with it for a week, returned it to Costco, and I decided to give Netgear another shot.
So I got AX8 5700 from Costco 3 week ago. Wanted to use a wifi 6 router, since most of my devices are compatible.Exact same issue other are having.
iPv4 or IPv6 didn't seem to matter.Constant disconnects. Both the TV and the Xbox one X disconnect simultaneously. Oddly, the windows 10 PC on port one never disconnects.
Swapped out the Cat5e's for cat6 on the Xbox, no dice.
My son games and I ask him, when I get disconnected, he says he is still online. I tried static IP's for all of my devices. Worked for about 48mhours. I have to power cycle the router to reconnect my devices, or reboot the devices.
Both the LG TV and Xbox, show not connected via LAN. Previous nighthawk X4 was flawless with the identical setup.The 5ghz network just disappears, and when I log into the router, the channel number just shows ASCII type jibberish.
Have to reset or power cycle to get the 5ghz back.
latest firmware, have not reverted to prior firmware, seem pointless.
I have reset to factory settings, still no long term resolution, as if a day is long term, but for this issue it is.
I haven't had issues like this in over 20 years dating back to 802.11b, when it went mainstream.
Last I check, it's 2020 and we didn't just start using wifi and Netgear most certainly should be able to fix this after the first post popped up.
I have spent too much time trying to resolve an issue I should not be having in this day and age of wifi, especially LAN issues.
I feel like I'm back on AOL dial up, just waiting for,the next disconnect.
Going to return this and hook my X4 back up, until I can decide which brand and router I will be getting.
- Christian_RJun 10, 2020NETGEAR Employee Retired
Hello nchtrs,
Welcome to the community! Have you had a chance to contact our Support Team regarding this?
https://www.netgear.com/support/default.aspx
Christian
- K-Mo81Jun 14, 2020TutorSo I did the latest firmware and had really high hopes. I made it close to a week with no disconnects on the PS4. Then tonight, it happened again. One disconnect in a week is better than none but still disappointing that it isn’t 100% fixed yet.
I am in the middle of working with Netgear support but my last contact was before the firmware and they were looking at my debug log. - K-Mo81Jun 14, 2020TutorCorrection, one disconnect a week is better than one to two a day.
- nchtrsJun 14, 2020Tutor
I haven't had a chance to goto Costco and do a return yet, so this week I decided to power cycle the router for 10 seconds every evening, and only the router, not the modem. The outcome was no surprise, no disconnects have occurred at all, and everything works as it should. I do work for an ISP and have been dealing with trouble shooting wireless routers since they were first introduced. We used netgear for many years for our customers. All the usual SOP trouble shooting has been done. It is definitely a firmware issue. The corrupted/ASCII WiFi channels are all telling in this regard. My internet equipment is on a battery backup, so power flickers do not occur on the router or modem as they always have a consistent and steady power source. I also have maintained my static IPs for my devices as well out of curiosity. Damn thing works perfectly, as it should without a power cycle. I only ever made it 4 days without an issue when I first got the router and then the issue became more erratic and frequent, sometimes only minutes between disconnects, then it would be fine for an hour or two. The odd thing was, a power cycle only corrected the issue for a brief time. I also never did a factory rest until my 5ghz ssid just disappeared and the 2.4 ssid was present, but I could no longer connect to it either and I could not make any changes because of the firmware corruption. I could not even click on channel selection drop down, it did not exist on the 5ghz menu, but it was fine for the 2.4. The new firmware works as long as I powercycle, its the long term, where it is expected to just work and not require a power cycle, as my old tried and true X4 behaved, that I miss.
- GabboCHJun 14, 2020ApprenticeWill be interesting what feedback you get from the support.
I sent around 5 logs with wifi & LAN dropouts in separate logs without any feedback except "please take some more logs".
The support team didn't even know a new firmware was released when I asked them about it.
It doesnt take much for Netgear to pick one of the users closest to them & stick an engineer on a plane to visit & debug the issues on site given so many people have the exact same problems.
Or least take back a few of the problem routers & reproduce a similar setup in the test lab.
The lack of any feedback or public information about these issues makes me sure Netgear know about the cause but don't want to own-up.
I guess replacing hardware where only a small percentage of users actually recognise the problem isn't cost effective - txchukoJun 15, 2020Guide
I wonder if setting up an auto power cycle with a programmable power outlet plug would case any kind of damage to the router in the long run. Could be set up to run daily or eveyry ither day at any given time.
nchtrs wrote:I haven't had a chance to goto Costco and do a return yet, so this week I decided to power cycle the router for 10 seconds every evening, and only the router, not the modem. The outcome was no surprise, no disconnects have occurred at all, and everything works as it should. I do work for an ISP and have been dealing with trouble shooting wireless routers since they were first introduced. We used netgear for many years for our customers. All the usual SOP trouble shooting has been done. It is definitely a firmware issue. The corrupted/ASCII WiFi channels are all telling in this regard. My internet equipment is on a battery backup, so power flickers do not occur on the router or modem as they always have a consistent and steady power source. I also have maintained my static IPs for my devices as well out of curiosity. Damn thing works perfectly, as it should without a power cycle. I only ever made it 4 days without an issue when I first got the router and then the issue became more erratic and frequent, sometimes only minutes between disconnects, then it would be fine for an hour or two. The odd thing was, a power cycle only corrected the issue for a brief time. I also never did a factory rest until my 5ghz ssid just disappeared and the 2.4 ssid was present, but I could no longer connect to it either and I could not make any changes because of the firmware corruption. I could not even click on channel selection drop down, it did not exist on the 5ghz menu, but it was fine for the 2.4. The new firmware works as long as I powercycle, its the long term, where it is expected to just work and not require a power cycle, as my old tried and true X4 behaved, that I miss.
- nchtrsJun 15, 2020Tutor
I returned it to Costco yesterday. I'll wait for the next revision and give them another go. I like being a first adopter, however not at the expense of my sanity. I understand nothing is perfect when it first comes out, but LAN should always work, without the hoops to jump through.
- SINCALTREVOct 21, 2020TutorThe AMPLIFI Alien. Best router I’ve ever had. I’m approaching 40 devices, that vary with Wifi 4, 5 & 6 and they all work fantastic. They are smart home devices like light bulbs, iRobot roomba, smart outlets, 2 security cams and more and I’ve never had connection issues. PS4 download/upload is actually better on this router. I can’t stress enough look at Amplifi’s offerings!
- ChocobofarmOct 21, 2020GuideI use a tp-link ac tri band router as my main router for LAN connections and everything works fine. The RAX80 is connected to it via a CAT6 cable and works as a wifi access point only. It's actually a very good AP. But, it sucks as a router.
