Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
txchuko
Apr 08, 2020Guide
If you havent tried the following please do so
log on to router web interface
under wan or lan in the advanced settings, disable port scan.
also if you are having issues with multiple consoles, also in wan or lan, set nat filtering to “open” or “off.
