Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
txchuko
Apr 09, 2020Guide
Reposting so someone who is having issues with lan disconnecting can see if it helps...
If you havent tried the following please do so
log on to router web interface
under wan or lan in the advanced settings, disable port scan.
also if you are having issues with multiple consoles, also in wan or lan, set nat filtering to “open” or “off.
- K-Mo81Apr 24, 2020TutorThe newest firmware that came out has not corrected this problem. Such a shame! I can’t even use the lan cable for my computer now either.
- metteduApr 24, 2020Tutor
Has anyone gotten the support contract from Netgear and held them to the fire and told them to fix it yet?
Tried it and still same problem after about a day.
- Panda9Apr 24, 2020GuideFinally got me the nest mesh and I can't believe what i was missing out on, i can finally update my programs after over 3 months of struggle, its been a daily issue and im about to set this thing on fire and post it on YouTube
- SINCALTREVApr 24, 2020TutorI’m tellin ya! I got the AMPLIFI Alien. I’m hooked! Slick app interface and awesome performance. I am never recommending/buying a anetgear product again!
- NmouneimneFeb 13, 2021Apprentice
I have the same issue as well.
Back in post 38 txchuko posted the following:
Did anyone trying to see if it worked for them long term?
- NeckGearNatFeb 14, 2021Tutor
Yes tried this and it didn't work. My only workaround was to connect my console directly to my ISP's cable modem.
- Matt1979Jun 21, 2021AspirantPs4 standard hard wired playing
c.o.d. modern warfare/ warzone
Lan disconnects at random during game play.. !! Any help w. With fixing this..?- NmouneimneJun 21, 2021Apprentice
Many of us are experiencing random disconnect from Lan. It seems Netgear is not acknowledging the issue, so I am not expecting a firmware fix.
I started using an unmanaged switch connected to the RAX80, and so far, so good.
