Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
txchuko
Apr 09, 2020Guide
Reposting so someone who is having issues with lan disconnecting can see if it helps...
If you havent tried the following please do so
log on to router web interface
under wan or lan in the advanced settings, disable port scan.
also if you are having issues with multiple consoles, also in wan or lan, set nat filtering to “open” or “off.
mettedu
Apr 24, 2020Tutor
Tried it and still same problem after about a day.
- Panda9Apr 24, 2020GuideFinally got me the nest mesh and I can't believe what i was missing out on, i can finally update my programs after over 3 months of struggle, its been a daily issue and im about to set this thing on fire and post it on YouTube
- SINCALTREVApr 24, 2020TutorI’m tellin ya! I got the AMPLIFI Alien. I’m hooked! Slick app interface and awesome performance. I am never recommending/buying a anetgear product again!
