Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
Hugesock
May 11, 2020Initiate
Same problem. Two wired PS4’s which disconnect randomly every other day or so.
Very dissppointed to learn that so many other customers face the same issue, and yet there is no answer from netgear.
My simple solution: I’ve put a cheap swich between my fiber modem and the router, bypassing the $400 router as far as wired connections goes. That seems to do the job. Not happy with the product and lack of service though :(
Chocobofarm
May 11, 2020Guide
I'm using a similar workaround: I'm bypassing the $400 RAX80 router by using another router for my LAN connections. As it is, I'm using the RAX80 solely as a wifi access point that's connected to my router. The RAX80 currently isn't reliable as a LAN router. I wonder what NETGEAR is doing about this issue. It's indeed a big problem to have for a $400 router.
- GabboCHMay 11, 2020Apprentice
they are doing nothing.
Just look how many issues there are & how long they have been open without any acceptance or feedback that there is a problem they are looking into.
