Clovers
Jul 09, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
Nmouneimne
Apr 21, 2021Apprentice
NaibStilgar - You said you were working with support, has Netgear appeared to acknowledge the issue?
Have they been sending you beta firmware to test?
In the past I worked with them when I had a R7800 and the Readyshare wasn't working. They would send beta firmware until they got it right. I suspect they don't do that anymore.
rudziankou
Apr 21, 2021Aspirant
I returned this piece of crap back to the store. I bought asus rt-ax88u router. It works perfectly.
