Clovers
Jul 09, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
Str8UpSucio
May 21, 2021Aspirant
I've grabbed 4 replacements from (B&H, Amazon [sent the CANADA vz.] and Walmart) same exact issue constant lan drops, supprisingly I've gotten the Wi-Fi to stay super-fast, solid and stable but the LAN JESUS!!! my PS5 constantly drops connections mid games. The only difference I see in the replacements is the new ones have the fan removed and are a bit lighter in color. The LAN drops are less frequent but they are there nonetheless. I've tried a switch but its the same difference since, the switch must go MODEM > ROUTER > SWITCH. At this point since most of my devices are WIFI conncected I only run the PS5 via LAN, I was considering keeping the RAX80 if there was a way to make it so the SWITCH feeds the ROUTER.
Ultimately if I keep getting drops ill just have to revert back to my WRT3200ACM, God why did I leave Linksys (loyal for decades) for this Star Wars Imperial Shuttle.
NeckGearNat
May 22, 2021Tutor
Yeah I plug my consoles direclty into the cable modem and bypass the router now. Then use the routers wifi for the rest of the house.
- NmouneimneJun 11, 2021Apprentice
Latest Firmware 1.0.4.120_1.0.61 did not solve the issue.
