Clovers
Jul 09, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
Matt1979
Jun 22, 2021Aspirant
Ps4 standard hard wired playing
c.o.d. modern warfare/ warzone
Lan disconnects at random during game play.. !! Any help w. With fixing this..?
Nmouneimne
Jun 22, 2021Apprentice
Many of us are experiencing random disconnect from Lan. It seems Netgear is not acknowledging the issue, so I am not expecting a firmware fix.
I started using an unmanaged switch connected to the RAX80, and so far, so good.
- Matt1979Jul 06, 2021AspirantWhat port number on back of RAX 80
did you plug the unmanaged switch into..??
