Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
NeckGearNat
Jun 21, 2021Tutor
Yep. It doesn't have to be a router though. I've been using a simple ethernet switch infront of mine and haven't had one disconnect since.
Chocobofarm
Jun 21, 2021Guide
Good point about the switch. I used a router mostly because I wanted to have all of my devices on the same network. Also, I'm not sure my ISP provider would support having a switch in front of the router. Bottom line, the RAX80's wired ethernet is broken and Netgear doesn't seem to care
