Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
Jul 31, 2022Guru - Experienced User
Has anyone given the newer RAX80 FW version a try? Haven't seen anyone post problems with it:
Please load it up and give feed back there.
Djg1984
Jul 31, 2022Guide
If it helps in any way my setup is
Virgin media 1gb fibre broadband
Virgin media superhub 4 in modem mode
RAX70 wifi router in router mode
Netgear 8 port ethernet switch with various devices wired including xbox series x, sky q, pc, synology nas, denon x3700h, cyrus music streamer, LG C1 OLED TV. Ethernet disconnection issue is mainly noticed on xbox and sky q as they are the most used devices and both get kicked out at the same time so pretty sure its not just related to 1 device.
- FURRYe38Jul 31, 2022Guru - Experienced User
What CAT# lan cable are you using in between the modem/ONT and Router and inbetween the router, switch and LAN devices. CAT6 is recommended.
What model Switch are you using?
- Djg1984Jul 31, 2022GuideMost of the ethernet cables are at least cat 5 but there is at least a couple of them which are newer cat 6 cables. Im sure the cable from modem to router is cat 6 and also the cable from the switch to router is also cat 6. The switch model is netgear GS308V2.
It's recommended to run same version of CAT# cable and not mix newer versions with older versions.
Also CAT5 does not officially support 1000Mpbs connection rates. 5E is were that started. Cables are fairly inexpensive these days and you might take a overall sweep and upgrade to all CAT6 to be sure all is good there.
