Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
Jul 31, 2022Guru - Experienced User
Well lets hope this maybe helpful to the RAX80 owners since this is a RAX80 thread. I wouldn't presume they are the same however may not be much different either. Anything is possible when it comes to these things.
Enjoy your RAX70. Be sure to save off a new backup configuration to file. Saves time if a reset is needed.
Djg1984
Jul 31, 2022Guide
Im aware this is an rax80 thread, was just the closest possible thread i found with people experiencing the same or similar issues. I dont believe there is massive difference compared to the rax70 in general but could be wrong
- FURRYe38Aug 02, 2022Guru - Experienced User
RAX80
- Using BRCM chipset (Quad-Core 1.8GHz processor)
- 8-stream Dual-band
- 4x4/160MHz + 4x4 (4.8Gbps + 1.2Gbps)RAX70
- Using BRCM chipset (Quad-core 1.5GHz processor)
- 8-stream Tri-band
- 4x4/160MHz + 2x2 + 2x2 (4.8Gbps + 1.2Gbps + 600Mbps)As you can see, there are "some" differences.
