jestiferhenri
Feb 03, 2023Follower
RAX80 randomly disconnects LAN
Hello,
Haven't checked back in this thread in a long time. After I did my workaround of putting a switch in front of the router I had serious disconnects. I stopped upgrading the firmware on the ro...
Kitsap
Feb 03, 2023Master
jestiferhenri wrote:Hello,
Haven't checked back in this thread in a long time. After I did my workaround of putting a switch in front of the router I had serious disconnects. I stopped upgrading the firmware on the router as I was worried it would cause the issue to reoccur somehow. (if it ain't broke don't fix it) Please help.
Regards
Jestifer
Please help with what? A full description of your problem and configuration would be useful. Disconnects with devices connected via Ethernet? Via Wi-Fi?
In particular, what is the brand name and model number of the modem/gateway/ONT that is connected upstream of your RAX80?
What firmware version is on your RAX80? The "latest" is not an answer. A version number helps with confirmation.
