allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
allarone
Jun 20, 2019Star
Thanks for the suggestion! I’ll try backing it down and see if that helps.
BubbleCat
Jun 23, 2019Star
Be weary! From what I can tell, Sam the Gam is the only one who seems to have little to no problems running *.56 firmware.
I had to downgrade to *.40 because .56 is a crap show.
- BubbleCatJun 23, 2019Star
Here's the thread with all the .56 woes:
- allaroneJun 24, 2019Star
Thanks for the additional info. I kept getting a failure trying to load .56. For now I stayed on .58 but I turned off Smart Connect. Turning that off seems to have helped tremendously. I'm going to watch it and see how things go. Worst case is I go back to my R8000 and wait until Netgear figures out its firmware issues :)
- Christian_RJun 25, 2019NETGEAR Employee Retired
Hello allarone - I'm interested in the issue you're reporting. Looking forward to your next update!
~Christian
- maloycolbertJul 01, 2019Aspirant
What are some known issues with .40? I am having the same issues as this post and decided to downgrade to .40, but dont want to start turning on QoS and MU-MIMO and smart connect if those are buggy. Even though I would love all of those features
- BubbleCatJul 01, 2019Star
.40 still will experience intermittent disconnects, but definitely not at the frequency of .56 and .58
- maloycolbertJul 01, 2019AspirantYeah it got unusable at .56 and .58. I wish I put it together that it was a firmware update, but the update happened right around the time I moved to a new location and everything I was thinking about got jumbled up. just downgraded and it’s already substantially better at connecting for my smart tv (which is where I saw it the worst at)
- SAM_the_GAMJul 01, 2019Luminary
I am using 1.0.1.56 because I feel it is slightly faster then 1.0.1.40 on DFS Channel (108) 5 Ghz Wifi band with Wireless AC devices.
And even when I downgrade to 1.0.1.40 under the GUI version it still said 1.0.1.56 for GUI version but firmware version 1.0.1.40. I did not experience disconnects with 1.0.1.56 only with 1.0.1.58.However, I have MU-MIMO, AX WIRELESS, Beam Forming turned on. I am not using Smart Connect and QOS.
- dragonpakSep 23, 2019Tutor
you off MU-MIMO and keep the AX , then it is ok, I have the same issue
