allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
cliff344
Oct 28, 2019Apprentice
I recently picked up an RAX80, replacing an X8 (R8500). After updating it to the latest firmware, and getting it all set up to drop in and replace my X8, I find out how bad this router really is. I am very well versed with Netgear routers having used and owned previous an AC1450, R6250, R6700, and X4, and X8. All of these worked very well for me, as each was purchased as an upgrade to the next. This new RAX80 is by far the worst I have ever purchased. First time through setting it all up, had it up and running, and about an hour later, it reset itself and lost all settings back to factory settings. So then I spend another hour getting it set up again, and it seems to run very well. Go to bed, get up in the morning and all internal connections are lost and Wi-Fi signal is nonexistent. Reset, and same thing happens next day/night. Go back checked all settings and made a few small tweaks, and was running extremely well once more. Go to bed, next morning everything is disconnected again. Having my home set up with HA, it's important that my router is stable and working without this type of thing happening. So for now, I have a large very expensive paperweight, until Netgear does something to fix it. All of my previously routers ran for months with the need to be rebooted, this thing can make it 12hrs. Netgear please address this. This is the biggest piece of garbage I have ever had from you!
BubbleCat
Oct 28, 2019Star
cliff344 Probably saying 'welcome to the club' is the wrong statement here. It's not a club you want to be in =(
For me personally, I'm running on an older firmware version and aside from missed security updates, and my VPN acting strangely, my router is mostly stable. You might try downgrading and see if you get stability there. I don't even know what the latest is anymore these days...
- cliff344Oct 28, 2019ApprenticeI would like to try something, but you mention VPN issues, and thats another important feature I use/need regularly. So I’m not sure I even want to try that either.
- cliff344Oct 28, 2019ApprenticeIt is truly a shame that Netgear doesn’t spend more time proving out these routers in house or by beta testing prior to releasing. What amazes me even more are features like media server that hasn’t worked reliably on any of the 6 different Netgear’s I’ve owned yet it’s still part of the GUI and firmware. It almost seems like they just take the same GUI firmware and try and adapt it and make it work for all the new routers, instead of taking the time to build them from the ground up for each device. How is it that individual developers who develop firmware such as DD-WRT can make it so much better on a small budget, yet Netgear which I am sure is a multi-million dollar company can’t sell you a better product off the shelf without these types of issues?
- Christian_ROct 30, 2019NETGEAR Employee Retired
cliff344,
Thanks for taking the time to post your experience. I'd like to ask if you've been able to get in contact with our support team. If not, please send me a message with your contact info and serial number.
Looking forward to working with you!
Christian
