allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
anthonjhnon1
Nov 03, 2019Guide
I've always read reviews on products where I was having similar problems and either fixed it from comments, waited until a fix was coming, or just lived with it. However this is a much different case because house runs on wifi and more importantly my home security. So this is my first time ever writing a review. I'm having constant disconnects and I have to admit to my wife that I bought something that's a piece of crap. Giving her the chance to say I told you not to buy it. I"ve always bought Netgear routers because they have always been stable and reliabile which made me happy. This is my first chance wanting to buy top of the line router ($300+) and I fell stupid. Please fix this issue. I don't care if you have to disable a few features, but at least make the connection stable.
anthonjhnon1
Nov 03, 2019Guide
And yes I know I have some spelling errors, typing in frustration and in a rush to go to church.
- cliff344Nov 04, 2019ApprenticeI sat down on Sunday and tried once more to play with the settings and see If I could get this thing to stay working for more than 12hrs. To no avail, still having issues. While trying to manually set the wifi channels instead of auto select, I noticed when doing so, the guest network started showing up, even though it was set to off. So I turned it “on” and the guest network disappeared. So by turning it on in the GUI it shuts off, and by turning it off, it turned on. Another knock to this dysfunctional firmware. I have to ask this question to all you including support. Has anyone, and I mean anyone ever gotten this router to actually work and use it on a daily basis without an issue? Secondly shouldn’t we consider class action lawsuit for refund and force netgear to quit ripping people off making them take this product off the shelf since it clearly does not work, and Netgear has stolen our money? Netgear is fully aware of this yet they have done nothing about this. In comparison, you bought a new car, and it only runs for 2 hrs and shuts off. How is that any different?
