allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
anthonjhnon1
Nov 11, 2019Guide
I've been a netgear user since 2008 but I think it's time for us to part ways.
kingjahrome
Nov 12, 2019Star
My WIFI routers have all been Netgear going back to WRT54g, and then N600. So I've used netgear exclusively over a decade and a half. WRT54g was rock solid on stability. N600 had the occasionally lock-up but it had literally months of up-time before any issues. Unbelievable that they can ignore this issue on RAX80 where up-time is never longer than 24 hours, and usually requires resetting the router several times a day.
- cliff344Nov 13, 2019Apprentice
We need to get a good class action lawyer to step in here and stick it Netgear. Most of should demand refunds for this $300+ piece of junk.
- Bigtime68Nov 19, 2019Guide
Netgear, any feedback on this serious issue?
- Christian_RNov 21, 2019NETGEAR Employee Retired
Hi Bigtime68,
Our engineering team is looking into the reports that are coming in. We'd like to work with you on some of the issues you're reporting. If you're interested, please send me a message with your contact info and serial number.
Thanks,
Christian
