allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
TomM_RAX80
Dec 19, 2019Aspirant
Christian,
I am a software developer and have been a beta tester for years for different products. I am more then happy to be a beta site and test fixes within 24 hrs of recieving them. I was very stable until just recently. The two big changes I recently made: added a Samsung SmartThings hub to my system and upgraded my BIOS. I think it was either 56 or 58. I have several Fire TV 4K sticks. These seem to be affected first. I have several Echos too. They seam to be very suseptable too. Phones and computers seem to hang on a bit longer, but eventually they lose their connection too. A reboot of the router ALWAYS solves the problem. Today was the worst as even the hard line ethernet devices failed too. I reboot 3 to 5 times a day.
I will run without the SmartThings hub connected for 48 hours and see if that was interfering or overloading the router. They are about 3 feet away from eachother. But if they are on seperate channels, then you would think it shouldn't be a problem. If you want me to send you logs, please email me specific settings for the debug mode.
Thanks!
