allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
anfibil
Dec 01, 2019Initiate
What a piece of junk! I just "upgraded" to this router as well (after seeing moderately positive reviews online). Nothing stays connected to it on my 5Ghz network. I spent hours trying to figure out why my 3-year old asus router was giving me higher speeds than this. That problem is still not solved. But it's hard to even try to work through it because every 5min my devices keep dropping out of the network. Come on, Netgear! This is not a $10 router. Ridiculous.
BubbleCat
Dec 19, 2019Star
anfibil , sorry you got duped by the reviews online. Every time I see positive reviews for this router I cringe and want to respond in the comments, but I just don't have it in me to make accounts for the various sites.
They seem to review them for a short amount of time and don't really put the router through the ringer like a regular customer would.
This router really is a piece of crap.
