allarone
Jun 20, 2019Star
RAX80 regularly disconnects devices, then they reconnect
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reco...
- Jan 29, 2020
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
cliff344
Jan 01, 2020Apprentice
Well new firmware released mid Dec (1.0.1.70). Pulled my $400 piece of junk out it's box to see if maybe they actually did something to make it usable. Loaded new firmware, reset up with my settings and got her going. Ran very well and impressive for about 30hrs, then once again, total disconnect to both wired and wireless devices. Reboot, and within 24hrs did it once again. Somehow it seems to be related to the time or time server setting. Whenever it disconnects, it shows a future date and time change in the logs. Also new firmware will not hold device icons and descriptions in both the GUI or the app. I was however very impressed with the wifi speeds (when it was working). Well back in the box it goes to wait on Netgear to get off their butts and try again. I am really beginning to love my R8500, as it never requires any attention, it's fast, and just works, unlike this piece of garbage!
GabboCH
I did exactly the same, out of the box, factory reset, update, setup & I had Ethernet dropouts (which was new for me).
Back in the box the day after.
